when I convert a divx-movie with TMPGENC to svcd (pal), I just get a video without any audio.
I also tried demultiplexing video and audio before converting, it doesn´t help.
Even using the external tooLAME-audio encoder didn´t help me.
What else can I do?
I´ve used version 2.02 and just read that 2.50 is available under tmpgenc.net -> I will try this after work...
But this problem seems not to bee a single failure, look at the forum unter tmpgenc.com, many people have this problem but no one has received an answer yet.
THANX for help.
try opening the divx in Virtualdub. Save the sound. Save the picture (no sound, direct stream copy). then encode separatly. then just multiplex, if not in tmpgenc then in BBmpeg.
if it donesnt help and if you have CCE, mail me.
Well, I am the slime from your video.
Oozin' along on your livin'room floor.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 17:28 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37
