Hi all:
I have the following problem:
I have 2 subtitle files for the same movie, but none are good.
One has wrong FPS and correct spelling.
The second has a bad spelling but a correct FPS.
Is there any quick solution to convert them into a good one ??
Can it be done with Subtitle Workshop ??
I checked but didnt find any quick solution to do it, as manually it will take too much time.
tks for yr suggestions.
hilario.
Open subtitle in subtitle workshop ... the one with wrong timing
Press shift + ctrl + t ... load file with correct timing .
Check and confirm all is fine , then save .
Wether it work's is another thing ... you may need to do some fine tuning still .
For fine tuning I prefer visualsubsync . -
Tks Bjs:
As soon as possible I wil give it a try.
Will let you know if it works.
hilario. -
Well it works.
The only problem is that one of the files has more dialogs (or subs) than the other.
That makes the diffrence I think.
I have tried with visualsubsync but I still dont know how it works.
Will give ir a try.
tks again.
hilario.
Subtitle Edit Help
By Soixante in forum SubtitleReplies: 0Last Post: 15th Jan 2012, 14:46 -
Edit Subtitle Megui
By bebado22 in forum Video ConversionReplies: 2Last Post: 28th Sep 2010, 21:13 -
Basic Edit from Subtitle Information
By none295 in forum EditingReplies: 1Last Post: 18th Mar 2010, 13:59 -
Edit subtitle times only?
By Charmer in forum SubtitleReplies: 3Last Post: 21st Feb 2010, 05:48 -
edit subtitle's font and color
By paseo in forum SubtitleReplies: 19Last Post: 4th Feb 2008, 05:32
