I've got a Sony KDFE50A10 LCD Projection TV with a bulb that will have to be periodically replaced. Word says that they last two years or so. But I understand the wear and stress on lightbulbs is when they're turned on and off, and not on the actual time they spend burning. Since I tend to watch the set several times daily, I've gotten in the habit of leaving it on between viewings, and turning it off at the very end of the day when I know I'm going to bed.
Does anyone know if I'm really extending the bulb's life or not? Do the Sony's measure bulb life with an "odometer" of sorts, and prematurely "disable" the bulb after so many hours, even if it still may have more life left in it?
yes - they disable the bulb based on hours ... also the performance decreases with age and as with all lcd panels - lcd panels also lose transparency the more they are used ...
the standard is -- shut the bulb down at 1/2 the expected max life ..
they do this because if the bulbs blow (they are under very very high pressure) - they could cause damage to the electronics and/or the user... also at the 1/2 life mark (when they are replaced) , the light output is only in the 70% range of a new bulb .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Generally the bulbs in RP TVs today last about 6000 hours. Your manual should tell you. Guestimate how long that will take you to go through. Also, a new bulb from Sony runs around $300-$400.
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 12:57 -
Rear Projection TV Help
By Alienverse in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 00:34 -
Projection TV
By joytimeday in forum DVB / IPTVReplies: 3Last Post: 4th Jan 2008, 00:57 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 13:29 -
anybody know how to refocus a projection tv?
By tonydahose in forum DVB / IPTVReplies: 2Last Post: 6th May 2007, 09:52
