I purchase a dazzle dvc II and am backing up vhs tapes. When i look at the "clip##.mpg", the audio is in perfect sync, however, when i use moviestar to take out commercials, the audio goes out of sync after a couple minutes. Since the software must be used to "produce" an mpg with audio/video together, i am not sure how to go about fixing this. If anyone has any suggestions on what i might do so that my audio stays in sync, I am all ears!! Thanks to all who decide to help me out
<font size=-1>[ This Message was edited by: Laribal on 2002-01-07 01:01:29 ]</font>
Try to capture with a clean source such as dvd and test your results. Use womble mpg2vcr to edit your captures. I rarely have sync problems using womble. Sync problems occur with the dazzle if the source is subpar, ie: old vhs tapes. Check out http://stop.at/dazzle2 for other DVCII discussions.
once you have captured your mpg file you do not need to use the software that dazzle supplies. if you cap is in sync and then it goes out of sync after editing then there is nothing wrong woth your source and it is a problem with editing. my suggestion would be to ditch the moviestar program once you have completed your cap and try other software like TMPGEnc for editing.
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
Two Quick Questions about Dazzle DVC 100
By Derangedyeti in forum Capturing and VCRReplies: 17Last Post: 23rd Dec 2010, 22:46 -
By Derangedyeti in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2010, 22:04 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 09:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 06:18 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 13:34
