just new in xvid and since i found out about it i am always watching movies in xvid format in my standalone player. but theres no skipping chapter. Is it possibe to put chapter in xvid? or in divx?
Results 1 to 11 of 11
Forgive my english, find it hard to learn and pronounce. Peace:)
Got nothing to do with XviD. Chapters come purely down to the container and avi does not support them. That is where the DivX Media Format comes in. Basically it is a hack/extension to avi and one of the things that it adds is chapters. Requires support from the player though.
mkv, mp4, ogm, dsm, etc. also support chapters. mp4 is the only one that might be supported by your player though (Nero Digital Certified). -
Originally Posted by celtic_druid
if a standalone player plays xvid, does it mean it plays mp4 as well?
ok I read some few FAQ about mp4, what software/application u can recommend which can do mux chapter to xvid?Forgive my english, find it hard to learn and pronounce. Peace:) -
my SAP jumps forward 5m everytime i press the right arrow the remote control, itsa kind of chapters function, have you tried it on yours?
I love it when a plan comes together! -
For mp4 I would suggest mp4box/yamb. If your player doesn't support mp4, then it won't work though. Also if your avi uses AC3 audio, it won't work.
mkv supports chapters
mkvtoolnix[mkvmerge] will allow you to add them -
thanks to all inputs. i tested Mp4, any files with extension (*.mp4) are not compatible with my player, though it plays xvid/divx. im not lucky.
hope theres another way.Forgive my english, find it hard to learn and pronounce. Peace:) -
I thought the latest version of divx supported chapters???? Have you tried looking at www.divx.com and searching for "chapters"??
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Divx Ultra certified players support chapters.
http://www.divx.com/certification/ -
you're right but will a simple fourcc change do the trick, i dont use xvid, have you two tried it?
if his xvid has GMC/QPEL etc that is not accepted by Divx format he will have to convert the xvid to divx. i wouldnt bother with it.I love it when a plan comes together! -
i tried avi file with *.divx is the extension but it didnt work with my player, however, when i change the filename extension to *.avi, it works but chapter not recognize by standalone player.. it maybe means my player is not divx certified.
i'm still looking for ways how to create chapter in avi hehehe (still dreaming). as of now, what i do to 2hours+ movies and titles(with numerous Musicvids/concert scenes/karaoke in it) are chopping the file so i can press "nextbutton" in my remote control).
Help! - How to put xvid into an mp4 container.
By jamsponge in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2011, 10:54 -
What is the best way to cut up an Xvid file or add chapters to it?
By Chrushev in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2010, 05:14 -
How do I get subtitles from a DVD to put into an XVid?
By Emanef in forum SubtitleReplies: 7Last Post: 23rd Jul 2008, 12:45 -
can i put chapters into a video using svcd2dvd
By dw1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 16th Jun 2008, 11:31 -
how many xvid can i put on 1 dvd
By peterg60 in forum Newbie / General discussionsReplies: 13Last Post: 19th Jan 2008, 05:56
