Hey,
I recently got rid of my old TV as the scart sockets were extremely loose and cables kept falling out. Anyway, my "new" TV, is one handed down to us from my girlfriends mum. Anyway, whenever I try to play a DVD, the TV switches to AV and comes up with a perfect picture...only that its not in full colour, but Green & Black.
Im sure theres a simple answer...only I dont know it. Any help is greatly appreciated.
Cheers,
Chris
Results 1 to 9 of 9
ain't love grand...
Are you using a PAL DVD player and outputing in PAL format?
Google is your Friend -
Yes I am - I checked before posting as I considered that as a problem.
The DVD player I am using is a Playstation 2.
Any ideas are most welcome
Thanks,
Chrisain't love grand... -
is it only with AV or with all the channels (BBCs, ITV, etc)?
if its all and the TV is a cathode ray, i would say your blue tube is broken...it sounds like it's only mixing red and green... -
Thats whats odd...its only when the TV goes to AV for the DVD.
Cheers for the reply though
Anyone else?
I noticed when I was setting up the progressive scanning and widescreen settings on my DVD player that I got false colours - in my case too much red. I would go through the set-up sequence for the video feed again.
Try to rule out the cables and the DVD player.
You can do this by ...
1.) Hook up your DVD player to the TV with a different set of cables.
2.) Hook up another DVD player to your TV with the same cables and then again with different cables.
3.) Hook up your DVD player to a different TV with the same cables and then again with different cables.
Remember the problem could be your DVD player ... the cables ... or the TV itself (bad input).
If the problem is a bad input on the TV then you are probably screwed.
- John "FulciLives" Coleman
*** EDIT ***
Also try with the DVD player(s) in both progressive scan (on) and progressive scan (off) modes."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Hey,
Ok thank FulciLives, that is a most helpfull post. I'll try that all out and see what happens.
Cheers man,
It sounds to me as if the DVD player is set to S-video output and the TV is set to composite colour input.
black in picture turns green
By heticu in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2009, 14:51 -
Why green noise or black in YouTube gallery stills?
By brassplyer in forum Video Streaming DownloadingReplies: 8Last Post: 8th May 2008, 00:23 -
Premiere Pro 7.0 or 1.x problem with green or black frames
By bruce & suzie in forum Authoring (DVD)Replies: 0Last Post: 6th Jan 2008, 12:27 -
Screen turn black when my Pioneer DVR-330 plays my homemade DVD-video
By dcmwong in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th Dec 2007, 13:58 -
By dcmwong in forum Authoring (DVD)Replies: 1Last Post: 6th Dec 2007, 10:58
