Everytime I convert my .avi files to DVD format, it always splits it into 4 .vob files.
I made sure the the split output option is not checked. So I don't understand.
Is there a way to make it so it converts directly to 1(or even 2) .vob files instead of spliting the .avi video file into 4 .vob files(Which are around 1.1 gig each).
And before you say to use a different program to convert, I use winavi because it haves the crop/resize feature(Which is userfriendly) and I need to use for my videos.
it creates a dvd and the vobs are then splitted every 1 gb, https://www.videohelp.com/dvd#struct
but why do you need one vob? you could instead try convert to one mpeg2 file. -
But if I choose mpeg2 format, then I will have to reconvert it to .vob(I use nerovision , to create the menus and burn the dvd, but it will re-encodes it, if its not in .vob format).
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Converting .mov file to DVD with WINAvi
By Bachskratcher in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2007, 11:50 -
Loss of sound after converting with WinAvi
By TheGift73 in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2007, 09:26 -
avi to dvd converting settings for winavi convertor
By soft in forum DVD RippingReplies: 6Last Post: 23rd Jul 2007, 23:45
