As you may have read in another post earlier, I have the TDA trial version and have ran into an error.
I am trying to author a dvd(I have done one successfully) of my own short home videos. In my next one, I wanted to include a small clip from a movie I own. So I went to source>add media(whatever). Clicked on the one that says pull from DVD-R blah blah. Insert the DVD-R, burned to the Harddrive. Put the movie into TDA, clipped the selection I wanted and when I hit ok, it tells me the video bitrate is too high for standard DVD. Says standard is 9.8...and that my clip is 9.81. Why is this, and how do I fix it? Do I have to burn the .vob files to HDD independently and then get a prog to change the .vob to mpeg2 and then go from there? Or is there an easier way to change the bitrate?
I tried just ignoring and going from there, but of course the video playback is choppy and distorted.
Would appreciate any info...
Usually clicking ignore on a "too high bitrate" commercial clip will play normally - such as trailers.
However you would have to reencode it to a lower bitrate. Use the tmpgenc editing program and drop it to like 8000 or so. There should be little noticeable drop in quality.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 16:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 04:17 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 12:16 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40
