Okay, I'm stymied.
I have a Shuttle running W2K (fully updated). The DVD player software that accompanies it complains about not being able to play any audio from any DVD I insert. VLC, however, plays fine.
So there are two questions:
1. How do I stop this Windows DVD player from launching automatically?
2. How do I rectify the "no audio" problem? I imagine this is because I need some kind of AC3 codec, right?
Thanks in advance!
If you want Autoplay to use VLC instead of WMP, click on the DVD drive, select 'Properties>Autoplay>DVD Movie'>Click 'Select an action to perform', then select VLC and 'Apply'. Or you can disable Autoplay completely if that's what you want.
The 'no audio' problem can probably be cured by AC3 Filter. -
Originally Posted by redwudz
Thanks very much. Right on both counts. AC3 Filter nailed the DCD Player issue immediately (with no config necessary). As Ron Popiel says: "Just set it and forget it."
Problems resolved.
DTS to AC3 audio conversion (using MP4Tools on a Mac) issue/problem
By SimonSimon in forum AudioReplies: 1Last Post: 1st Sep 2011, 04:41 -
How to stop Ripbot from auto deleating the temp file?
By cal_tony in forum Video ConversionReplies: 0Last Post: 5th Feb 2010, 13:36 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
AVS Video Converter and True-HD Audio (AC3+) issue
By lionelblair in forum Blu-ray RippingReplies: 3Last Post: 18th Sep 2009, 06:36 -
Free Avast - is there any way to stop auto updates.
By blinky88 in forum ComputerReplies: 4Last Post: 26th Oct 2008, 09:23
