    Jun 2005
    West Indies
    I have a weird problem. I used ffmegx to convert a dozen or so clips into mpg's with mp2 encoding. The clips were at various resolutions. I then created a 4:3 dvd with Toast 7 with re-encoding set to never.
    when I play the dvd some clips, most of them, play fine but a few distorts onto the left hand half of the screen. It plays fine with Mac's dvd player though..
    any suggestions? I have myDVDedit is there anything i could fiddle with there to fix it?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Could it be that those are SVCD resolution? 'Cause that's how my DVD player shows such files.
    Jun 2005
    West Indies
    ok, I re-toasted the dvd, but this time with encoding on, took a hell of a long time, but all the clips are showing fine now... I thought i could have saved some time by using ffmpegx to create the dvd ready files.. but i guess things don't work like that...
