I recently found out about H264 and I have a previous HD-MPEG2 file to convert into H264, apparently you can retain better quality for a smaller file size and I noticed converting HD-MPEG2 to XviD saw a loss of sharpness in the image.
So I got a H264 codec and tried fiddling around with it in VirtualDub. The problem is the source audio in the MPEG2 is 10MB so i thought I'll just keep that so I select 'direct stream copy' for audio.
The audio at the end of the file ends up being 30 something MB file. Why's it doing this? And the MP3 compression in VirtualDub only goes up to 56k
It's not just that, is there any program that will allow me better control over the size of the final product?
Results 1 to 16 of 16
If the source is MPEG audio then VirtualDubMPEG2 will decode it to PCM. You can either recompress the audio, or demux it into an MP2 file and then mux the audio back into the final AVI. I usually use TMPGEnc to demux the audio into an MP2 file and then encode with VirtualDubMod to remux the MP2 audio.
I would highly suggest that you don't encode AVC/H.264 via VirtualDub. Try MeGUI as suggested which uses x264 cli. AVC via VfW is just a bad idea.
Okay, I unzip the program and whenever I try to open the .exe I get an error that the program failed to initialize properly. =/
You can get .net 2.0 from Microsoft: http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15...displaylang=en
EDIT: Or use jagabo's link.
Okay, I have the program running and the program paths is the next problem. I've put the path in to DGIndex and the x264 encoder. I go to create it and its done after only a few seconds, I go to see its only created a d2v file and no video file.
What program am I missing? -
The log doesn't seem to say anything was wrong with encoding. I still only get a d2v file.
What programs DO I NEED in order to encode this file into a x264 file? -
See http://forum.doom9.org/showthread.php?t=112496
Need to create a .avs AviSynth script."Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 14:13 -
H264 in MPEG2-PS
By vid2me in forum Video ConversionReplies: 15Last Post: 18th Nov 2010, 14:10 -
Converting MKV (or h264) to MPEG2
By DeathStalker77 in forum Video ConversionReplies: 25Last Post: 11th May 2010, 21:15 -
H264 to MPEG2, best way ?
By boulder in forum DVB / IPTVReplies: 9Last Post: 30th Aug 2009, 17:49 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56
