I've started using TMPgenc DVD Author and like it for editing video and creating menus. Is it possible to add transitions to scenes? Some of my home video footage is pretty choppy and transitions help smooth it out? I appreciate any suggestions, but please keep in mind that I'm a total newbie to video. Thanks
TMPgenc DVD Author is for authoring DVD's only. It is used to make menus and burn the files to DVD. You need editing software to add transitions between your video scenes. Sony Vegas, Ulead, Pinnacle, etc. They all make video editing software.
Thanks. TMPgenc does let me do some basic editing, such as trimming scenes, deleting unwanted sections, and adding chapters which was something I needed to do.
I said I was nearly a total newbie, so pardon the dumb question: Will these programs allow me to import files I've worked on TMPgenc DVD Author and insert transitions? It appears to me that TMPgenc's working files, prior to authoring them into a DVD-compliant format, are some sort of proprietary format for TMPgenc, something like *.dvddata. Anyway, my copy of Pinnacle lite doesn't recognize them. -
I thought you were importing it from your video camera.Originally Posted by FinChase44E
If it is already in mpg format, use something like Womble to cut/trim (they also have a transition package, Mpeg Video Wizard).
TMPGEnc doesn't have a proprietary file system. That's only for the project files. It doesn't do anything with the files until you complete the project. -
To FinChase,
Hi. I have used MPEG Video Wizard for a long time. It's very useful for me. They have many transitions, also include 3D transitions.
You may try it.
-nightcat
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGEnc DVD author.
By netbuddy in forum Authoring (DVD)Replies: 20Last Post: 24th Aug 2007, 03:27
