When I use VIrtualDubMod (or VirtualDub or NanDub for that matter) to append two avi files I sometimes get the problem that at the new seam there is a high pitched, short sound and then the sound is nearly silent, gradually coming back over the next few minutes.
Anybody else got this problem and why is this happening? Much more important, how to fix this?
Best regards,
joe
Does the audio play properly on each file before joining? If so, then joining may be the problem. If you are converting them to DVD, don't join them. Let the authoring program do that. If not, VD does about a good job as any for appending. But someone might suggest a better program for joining.
It sounds like a corruption in the audio file. You could mux it out after the joining and run it through Audacity if it's MP3 or WAV. Find the problem area and replace it with silence, then mux it back in. I'm assuming the audio stays in sync the length of the joined video? -
The audio works perfectly while the files are still seperately and it is well in sync after the seam point.
Also this only seems to happen with AC3 sound. Haven't yet encountered one corrupted movie with MP3 audio. -
You may need the AC3 ACM decompressor installed. It is in the tools section.
It doesn't matter who you vote for. The government always gets in. -
I have dscaler and AC3filter installed, so what would AC3 ACM decompressor be good for?
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 02:53 -
Joining AVI Files in VirtualDub.
By eliqush in forum EditingReplies: 12Last Post: 6th Jul 2009, 03:31 -
joining 2 AVI files via VirtualDub or another program
By cfs6254 in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2008, 12:15 -
Joining avi files with Virtualdub
By JaredKnight in forum EditingReplies: 10Last Post: 8th Jul 2007, 20:45
