Hi, i have a freecom FX50 SL dvd burner but it started to get errors in burns, is
there a way to check if the drive is dead! am using nero 6 last update and it plays
and rips dvd ok, but just burning them it messed up on the last 10 burns maybe like
i had about 4 ok burns in the last 14.
Oh disks used
Datawrite Gray (8x) Burned 4x
Datasafe white printable (8x) Burned 4x
Poundland CmC (8x) Burned 4x
The first two things I would try is, different media, different burning program. Media can be inconsistent, even within a package. You could use DVD Decrypter or the newer IMGBurn and see if that makes any difference.
If no luck with either of those, try cleaning the laser lens.
You didn't say how the burns failed. Wouldn't play or just stopped in the middle of a burn? Nero should have given you a log if it failed in the burn. If they wouldn't play, try doing a scan of the DVD. What are you playing them on? A standalone or the PC? -
well the disk burn till the end and nero says that it has failed with funny looking ring in the discs,
i never tryed any of the discs in a dvd player, as i guess they will not work, the DVD burner is a USB2
one if that helps! also i use about 6 or 7 other disc makes and still the same. -
You could post your Nero log here. Just be sure to remove the Nero serial number from the log.
Or look here for Nero error codes and burning errors: http://ww2.nero.com/nero6/eng/FAQs_Error_Messages.html
I Know HD DVD is Dead
By wulf109 in forum DVD & Blu-ray WritersReplies: 17Last Post: 4th Sep 2010, 15:24 -
Dead Panasonic DMRES35V VHS/DVD Burner Combo
By Painasonic in forum Newbie / General discussionsReplies: 4Last Post: 4th Jun 2010, 15:26 -
Its official: HD-DVD is DEAD
By DereX888 in forum Latest Video NewsReplies: 65Last Post: 23rd Feb 2008, 21:26 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
Cheapest DVD+RW or -RW, I think mine is dead, help!
By Abouna in forum DVD & Blu-ray WritersReplies: 6Last Post: 18th Jun 2007, 10:36
