I am trying to record a live band performance, and it's so loud in there that the sound always comes out static-y. Is there a way to record loud sound like that and get better quality.
I'm using a sony hi-8 videocamera and it already has an auto adjust feature that makes the audio listen-able. I think it could be better though.
any thoughts?...
Big_Jit
use a better microphone that can handle high SPL levels ...
the hi8 has good audio recording capabilities - IF the preamp section can handle the dynamic range -- you may need to attenuate the signal coming into the hi8 by about 20dB - you can do this with an inline pad or a small battery powered mixer ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If it only has a built in microphone, try putting a Band-Aid over the microphone.
I've done that before with high levels of construction noise and it's better than just overloading the audio. (You might want to wear earplugs yourself if the band is that loud.)
Thanks for the reply guys!
I'll try the band-aid trick while i'm shopping for that mixer.Big_Jit -
I know it sounds dumb, but those fabric band-aids do the trick for me.
It depends on your onboard microphone, but if it just has a small hole that the band-aid can cover, it drops the volume enough most of the time. Easy to remove, also.
I just wanted to say that that band-aid trick worked like a charm!!!
Big_Jit
Capture stereo sound and quality video from analog camcorder to dvd
By gxwarr in forum Video ConversionReplies: 1Last Post: 6th May 2009, 17:39 -
TV Capture not loud enough
By programm in forum Capturing and VCRReplies: 11Last Post: 10th Mar 2009, 08:48 -
DVD movies Sound effects way loud voices... not so much.
By maxx409 in forum Newbie / General discussionsReplies: 7Last Post: 15th Feb 2008, 13:57 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Loud Static/Audio Clipping at end of Capture
By brandtb in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2007, 22:20
