hi people n00b here.i want to convert a movie to avi, i have tryed winavi works but i get no sound what so ever when converted.i think thats the only program so far what will let me select all vobs and convert to 1 avi
any recomendations?
many thx
There a quite a few ways. I would try FairUse Wizard if you want an easy way. It just needs a decrypted DVD file. You can do that with DVDFab Decrypter. AutoGK is another program that can do a DVD to AVI conversion.
Or you can use VOB2MPG to save out the whole DVD to one large MPEG file, then use VirtualDub Mod or similar to convert to AVI. When you say 'AVI', I'm assuming Divx or Xvid.
WinAVI isn't that great of a converter.
There are better freeware tools out there.
And welcome to our forums.
What about converting VOBs to DV AVI, specifically MainConcept type-2 DV codec which is already on the PC?
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
When you do the conversion ,have you seen a option"Enable DirectAC3",and have you tick it?Originally Posted by KX250
Most DVDs have 5.1 AC3, along with other audio formats. For most AVIs, you may want to use the 2 channel AC3 if it's available. I think FairUse may convert it all to 2 channel. One audio format that's new can use 5.1 AC3 for Divx/Xvid; Aud-X.
But your player would have to accept it. If it's only to be played back on a computer, you can use most any audio format you want.
Generally, if you can play it back on the computer, you can convert it without major audio problems. AC3 Filter should be able to play it. AC3 ACM Decompresser can load it into a program like VirtualDub (Mod).
Converting VOBs from a DVD to a single AVI
By aln688 in forum Video ConversionReplies: 25Last Post: 6th Apr 2010, 08:34 -
Joining multiple VOBs to make one AVI?
By RedCorvus in forum EditingReplies: 4Last Post: 6th Aug 2009, 09:57 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Can you set alltoavi to produce a single AVI from multiple VOBs?
By benvid in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2008, 11:25 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07
