Hi.
This problem steems back to when i first used this media.
http://www.ukdvdr.co.uk/shop/O1ne-Movie-Style-16x-DVD-R-50-tub-pr-17717.html
It was on a special offer, and it was the cheapest 16x media around,
so i thought i'll give it a go, i can see why! my hit ratio was 1 in every 3 - 4 if i was lucky,
when ripping this media, it caused the drive to speed up really fast and slow down, and now days this is how my drive works all the time.
I know there is sometimes when you are ripping media this happens, depending on what
you are copying, but this is totally differant to what i'm experiencing
There are also times it will only rip 8 - 10 mm of the same media and dies,
it's always around 8 - 10 mm no bigger, and other times it will rip to the end.
I thought it might be the media but it works fine on another drive i have,
and like i said there are other times it will rip to the end.
Is the drive broken or would it be a communication problem from computer to drive.
Have you updated firmware for the burner? If that doesn't help, I'd consider replacing the drive since very good drives are so inexpensive now (under $40 at NewEgg). Personally I like Benq, Pioneer and NEC in that order, and I also recommend sticking to quality media such as Taiyo-Yuden and Verbatim. I have a NEC 3520A which would burn Ritek G05 (8x -R media) at 12x with 3.05 firmware, but it refuses to burn them altogether after update to 3.07 firmware which emonstrates well how firmware can dramatically affect burning.
Hi.
Thanks for your reply, i have a pioneer 110, and the firmware
is up to date, i think ill go back to NEC, i've had two pioneers
and both have been trouble, the NEC 3520A i had was great, no problems at all.
Thanks.
DVDRW 2016UI - DVD Rewriter
By DVD-Writeoff in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Sep 2011, 12:18 -
Audio problems after ripping DVD
By ksimz202 in forum Newbie / General discussionsReplies: 3Last Post: 28th Mar 2011, 01:49 -
Laptop rebooting during burning with Pioneer DVD-RW DVRKD08RS rewriter
By rock_king_my in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Sep 2009, 04:04 -
Problems ripping my DVD
By KayAt in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2009, 16:33 -
Samsung Writemaster DVD Rewriter & Ripping DVDs
By rock_king_my in forum DVD RippingReplies: 1Last Post: 7th Dec 2007, 00:47
