    Jun 2006
    Planet Earth
    Hi all, I have a DVD that I want to cut the scene in main feature (in one of the main VOB file VTS_01_1.VOB) but I want to retain all the DVD's structure (menu, features, etc). Is there any way to do this easily without recreating a DVD structure? Something tells me that just using a VOB cutter program won't work!
    Thanks all for your help!
    Oct 2005
    I think VOBBlanker is the tool you want. It will allow you to blank out cells, and will fix all the pointers for you.
    Jun 2006
    Planet Earth
    Thanks, work like a charm!
