Results 1 to 11 of 11
    Jun 2006
    Okay. I admit I'm a video idiot. Most of it makes little sense to me. i only know that the only video I can get to play properly on my Mac is .mpeg. Not mpg4, not avi, not wmv. How can I convert my wmv files to plain old mpeg? I don't see that choice in the 'to' window.
    Now I've read the posts from lots of people who understand all of theis stuff a lot better than me. Frankly a lot of it is over my head. Sorry...I guess I'm just old. Maybe I'm trying to get this ffmpegx to do something it can't do. Or maybe I'm trying to use a fighter jet to get across the street when tennis shoes would work better.
    USA
    Since you are using a Mac, you would probably have better results asking this in the Mac Forum. Moving you.
    There are a fair number of dedicated Mac users here. They should be able to give you some ideas for converting WMV using Mac tools. I use my G4 mostly for graphics, so I'm afraid I'm not much help for Mac video work. I use a PC for that. (I know, I went to the 'Dark Side'. )
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Hello, and welcome to the Mac Forums!
    First, you are saying you need to get an .WMV file to play on your mac.
    The simplest solution is to go and download and install
    the Flip4Mac component, WMV Player.
    This will enable you to play MOST wmv files natively in Quicktime.
    The ones it will not play will be the WMV files that have been
    encoded with Windows DRM, making them Windows Media 10
    encoded files. For those, there is nothing that can play
    OR convert them for use on a Mac.
    If you are wanting to encode the WMV files you can play
    through the WMV Player, then it is as simple as converting
    those with Quicktime Pro, which is easily purchased
    from Apple for $30. What you are purchasing from Apple is a
    "key" which unlikes the Pro architecture of the Quicktime
    software already on your Macintosh, as each Mac ever made
    comes with a "lite" version of this software to do most
    small tasks, such as play movies, and encode Mp3s
    through iTunes.
    Post back once you have gotten and installed the WMV Player
    software, and we can help with further troubleshooting.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Jun 2006
    Thanks.
    I've checked my wmv files and they are Standard 9.
    I have the Flip4Mac WMV 2.0.1 componant, but my wmv files play really jumpy (both video and audio). So I started to think I should just convert them to the mpeg format I'm used to that always works for me.
    I also have Quicktime 7 Pro with the key installed. I notive that I can "export" to several formats but not mpeg. If I export to avi the movie plays smooth but I lose my sound. If I try to export to mov the export fails. If I "save as" mov I get the same jumpy playback.
  5. Member terryj's Avatar
    Ok, from your last posting it seems that:
    Video/audio plays "jumpy":
    This could be to a lack of a codec necessary to play back the file.
    This can be solved by when in Quicktime, Perform a Command -i
    and look ath the info box and see what codec it is calling for
    for both Audio and Video.
    export to avi, video plays smooth, no sound:
    Cannot export to mpeg:
    Again easily fixed. The fact that it is exporting the video
    fine, but not the audio to avi from the WMV means
    that again, you are missing a codec for that audio.
    The fact you cannot convert to Mpeg is because you
    do not have the Quicktime MPEG-2 component,
    a $20 add-on to QT Pro, that you can purchase
    directly from Apple at the Quicktime page.
    Here's what you should do:
    First find out what codec it is calling for with the audio.
    Second, google that codec and add "for mac" in
    the search term, so for instance "ac3 for mac",
    or "mpeg aduio for mac", whatever the case is.
    Third, download and install the codec.
    Fourth, once that is done play the wmv again,
    and see what happens.
    Fifth, and this last step is entirely up to you.
    You could go and download the QT Mpeg-2 add on from Apple,
    and pay the $20. OR you could simply export your WMV files
    to AVi, and then process them through ffmpegx, which you have.
    at this point, either exporting to mpeg will work, it depends
    on whether you wnat to pay $20 more or not.
    I would, but YMMV.
    Urban Mac User
    Oct 2003
    Canada
    In your details it says your computer is 500MHz - this could result in bad playback depending on the video resolution and bitrate.
    I'd recommend trying VisualHub to convert to MPEG
    http://www.techspansion.com/visualhub/
    Nov 2006
    I though somebody would suggest VisualHub.
    Okay I'm still using it in Demo mode, but so far absolutely None of the Web-downloaded wmv's I've attempted to convert with it to MPEG will do so without that 'friendly error' about settings maybe being wrong somehow, coming up. The furthest I can take them is AVI, and only that if I don't customise the settings.
    So apart from the $30-40 first-steps of Flip4Mac payware, from which you could at least get them to a nice malleable QuickTime .mov with an audio track that other apps on the OS X side could work with, WMV-to-MPEG still seems a bit beyond the pale in the Land of the Big Cats.
    Silversleeves
    Apr 2005
    Blacksburg, VA USA
    Why the demo of VisualHub, Silver? Why not the freebie
    iSquint from the same folk? I just dropped a WMV on it,
    and it converted to MP4 quite nicely.
    And why not the Flip4Mac freebie (not the payware)?
    Al Bloom
    Nov 2006
    Thanks for the suggestion for the freebie, albloom. The latest version of the free Flip4Mac stamps the video track (all frames) of files it converts from WMV with "Made with Flip4Mac Trial" or something very similar. Since my last post, I've been able to take wmv's to mp4 with about the same quality in output as the avi's I was making before.
    Silversleeves
    Apr 2005
    Blacksburg, VA USA
    When you're right, you're right. The Flip4Mac web site is only offering
    trial or pay-me stuff. To get the freebie go to microsoft.com and
    search for Flip4Mac. The QT components are still free there. The
    url is:
    http://www.microsoft.com/windows/windowsmedia/player/wmcomponents.mspx
    Al Bloom
    Nov 2006
    url is:
    That's the one I first installed months ago. It'd be going backwards, which seems pointless now I have another means of getting from wmv to mpeg. I happen to keep a copy of Cleaner 6 (and not the Pro of that either, coincidentally), which can take anything QT Player Pro would, if it were capable, into muxed MPEG1 to that format.
    I have toyed with the idea of getting the first "pay-me" from the Flip4Mac guys, just so I could WMV files with the same degree of flexibility as i DivX stuff, but as my standalone DVD player wouldn't know WMV from a hole in my head, I should continue to put off that expense.
    Silversleeves
