What's the easiest/quickest method/program for editing the author and title info on a few hundred MP3 and WAV files?
http://www.google.co.uk/search?hl=en&q=mass+id3+editing&btnG=Google+Search&meta=
You're really after a mass ID3 tag editor. I had a quick look at those results and turned up a couple of potential applications - see if there's something in there. I can't suggest anything, I'm afraid, as I have never needed to mass-rename my audio files (they're all named by CDDB when I ripped my originals to Ogg Vorbis). -
EagsOn, http://eagson.webcindario.com/ is free, easy to use.
If the files have no ID3 tags, it will take a while to rewrite them all. After that it's pretty quick.
MP3 only; I don't know anything that tags WAVs. -
SURE it does! You can use a number of programs to add and read the data (though most CD burning apps won't) -- CoolEdit/Audition, ProTools, etc. It's in the RIFF header as additional data fields. You can use RIFFView or others (Google: "Riff" and "viewer"). To read 'em.Originally Posted by olyteddy
Here's an example...
1. Simple small silent WAV file:
http://www.cornucopiadm.com/goodies/Silence_Mono8bit11kLPCM.wav
2. Simple small silent WAV file, with info added:
http://www.cornucopiadm.com/goodies/Silence_Mono8bit11kLPCM_BWF.wav
BTW (On-topic again), thanks for that link. Every now and again I could use a good mass re-tagger.
tsMuXeR and/or eac3to dropping sub-title info
By gene0915 in forum Video ConversionReplies: 0Last Post: 25th Jul 2011, 23:14 -
Easiest way to author dvd from other formats?
By Iwan2learn in forum Authoring (DVD)Replies: 10Last Post: 12th May 2009, 04:03 -
looking for entry level title/chapter/angle info
By anilty in forum ffmpegX general discussionReplies: 4Last Post: 27th Mar 2009, 11:57 -
Easiest way to edit Curse words
By glenn71x in forum EditingReplies: 37Last Post: 15th May 2008, 10:31 -
NEW problem, NO title info in DVD folder, gui4dvdauthor
By theewizard in forum Authoring (DVD)Replies: 7Last Post: 13th Jun 2007, 20:26
