ok , got lots of hdmi clips and theyr avi's want to put them on dvd so i can see the capability of my hd dvd and hd tv, do i just do a normal conversion avi(divx) to dvd?? will they still be hd?
or do i do something special
Results 1 to 11 of 11
no such thing as a hdmi clip == you must mean HD ..
unless you have a HD-DVD or blueray player or one that can play HD VC1 or HDCD .... you can not play HD clips in a set top box .
if you convert the divx clips to dvd - they will not be HD anymore ... and are you even sure the source files are really HD ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
That is the drag of it all. When I bought my new Philips player, I assumed wrongly that it would play the HD divx files I had downloaded off the divx site.you can not play HD clips in a set top box .
I guess the only way to do this is to use the video out from your video card to your HDTV?
ATI boasts that their new HDTV tuner card will record and burn HDTV to DVD and CD but I assume that that's to play through the media PC which seems to be the route alot of people are going with home theatre.
The HD DivX files I've seen are amazing on a 19" monitor and I bet they still look pretty good on a 61 inch HDTV. -
yep got a toshiba hd dvd player connected via hdmi and it plays hd, got some hd clips from divx.com, it plays divx and vcd, dvd etc, shall i just burn the divx clips to cd and play them or, how do i make a hd vcd or hd dvd??
thanks -
The Toshiba HD-XA1 and HD-A1 HD DVD models dont play DiVX HD as far as I know ... are you not sure you dont have a toshiba upconverting model instead ?
to make a HD DVD , you would need a HD DVD burner and media , currently about a $1000 for the burner..
no such thing as a HD VCD
what model toshiba do you have - otherwise this is turning into a guessing game ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
the pioneer dv-490v has a lot of problems with divx files ... nor will it play divx hd files ...
you can convert the divx hd files to divx sd and see if they play -- or not ..
or you can convert them to normal mpeg2 dvd format ...
any of the options above will reduce quality GREATLY......"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
this player doesnt have any of the great pioneer chips in it in fact i was just reading ..
good review (it has some good features)
http://www.dvdtimes.co.uk/content.php?contentid=61831"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I just noticed there are a few other HD Divx players:
http://www.divx.com/products/hw/browse.php?c=7 -
well - -two really , not exactly a huge number
multiple clips
By devdev in forum Capturing and VCRReplies: 0Last Post: 2nd Dec 2010, 11:36 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 18:03 -
More Clips
By ccc in forum Video ConversionReplies: 0Last Post: 7th May 2010, 22:06 -
Jerky clips
By kaikaiyeung in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 7th Aug 2009, 04:05 -
extracting clips
By turdburglar in forum MacReplies: 1Last Post: 15th Sep 2008, 07:29
