hi. i have a ton of videos just setting on my computer from a CVS Disposable Camera.
http://www.newyorkology.com/archives/images/disposablevideocamera.jpg
My problem is that the only way i can view any of these videos is through windows media player and Divx. I desperately need to edit them but when ever I attempt to import them to Premiere, the program just sits there at the importing dialogue box with zero progress. The videos are AVI files, and Gspot tells me that the needed Xvid codec is properly installed. So if anyone has any ideas on how to get Premiere to cooperate, your input would be greatly appreciated![]()
https://forum.videohelp.com/viewtopic.php?t=286294&highlight=premiere+xvid
and try install koepis xvid codec. -
thats what my premiere was doing until i got ac3 support.
http://fcchandler.home.comcast.net/AC3ACM/AC3ACM.zip
if all else fail demux the audio and import just video. convert the audio to mp3 and import it too -
Originally Posted by Baldrick
i did that today, and still no luck. once i open the .exe and let it install, is that all i have to do? i guess what im asking is, do i have to directly install the codec 'to' adobe or do PCs, in general, keep 'a pool' of codecs that video decoding programs pull from.
Originally Posted by drewzor
(just installed the AC3 suggestion, and still no luck) -
reading further on demuxing, i found a program recomendation on this forum (https://forum.videohelp.com/viewtopic.php?t=303787&highlight=demux) and just tried using it. still, no luck.
Sorry about that then, for me the ac3 codec helped a great deal for importing problems.
Premiere doesn't like xvid one bit, besides its best to edit video in a format that is less destructive. Generally converting to xvid is the last thing you should do to a video file, this is because the xvid format throws away alot of video infomation to compress to such a small size.
Download the huffyuv codec, its called a lossless codec because it doesn't throw away video infomation when it saves your video. For this reason the saved video file will be quite larger then the xvid file.
You should start by using Virtualdubmod
Load the xvid file and go to "video", "compressions", and select huffyuv. You dont need to change any settings in this codec, Simply save the video file.
Leave VDubMod open and you should try to open this file in premiere. If it doesn't load then its defenity a audio codec problem. you should always think of video as two combined files.
Premiere likes mp3 so go back to VDubMod and goto streams and then stream list. this will display all the audio tracks saved to the file.
First click demux (this means to seperate the audio from the video)
It will save in the format that its incoded into the video, so if you see its .ac3 you will need that codec I posted earlier Or you can simply select it to be mp3 and save.
Now you can disable this audio stream from the same list in VDubMod (near the demux button)
Save the video only in huffyuv.
Now you can import the video AND the audio Mp3 file seperatly into premiere.
Things you may need
The video codec
Huffyuv
the Audio encoder
http://www.free-codecs.com/download/Lame_Encoder.htm
And the decoder for acm to mp3 for vdub
http://www.free-codecs.com/download/AC-3_ACM_Decompressor.htm
And the decoder for mpeg4
http://www.free-codecs.com/download/FFDShow.htm
decoder for mp3
http://www.free-codecs.com/download/LAME_ACM_Codec.htm
Continued failure at importing audio from a DVD into Adobe Premiere Pro CS5
By msp1518 in forum AudioReplies: 0Last Post: 11th Aug 2011, 14:44 -
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 20:39 -
Trouble Importing avi file into Adobe Premiere
By Top Gun in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2010, 13:21 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 01:56 -
Problems with importing converted vob into Premiere Pro
By fishytastic in forum EditingReplies: 6Last Post: 16th Oct 2008, 14:18
