  1. Member spiritgumm's Avatar
    Jan 2004
    I have a movie file (4.35 gb) and wanted to put it on dvd with a small (10mb jpegs) data file. In Nero Express, I couldn't combine both file-types in "Bootable disc" or "DVD" making mode, so I used "Data disc" mode. I thought I would have to shrink the movie but Nero burned the complete project (4.37 gb) on a dvd+rw.
    Two questions:
    I thought 4.35 was as big as a dvd5 could be. Are there separate rules for dvd files and data files?
    I wanted to be able to see the jpegs in a computer, and play the movie. When I play the dvd in a player, it only sees the jpeg folder (not the movie). The computer sees both the iso and jpeg folder, but won't play the movie either. How can I burn both types on one dvd?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Put your AUDIO_TS, VIDEO_TS and another folder with the jpeg (keep it simple...like DATA) all in one "master" folder....create an .ISO image of the master folder with ImgTool Classic....then burn with either DVDDecrypter or ImgBurn.
  3. Member spiritgumm's Avatar
    Jan 2004
    Wow, thanks, it seems to work! But how can more than 4.35gb fit? Is it because I used an +rw (for testing purposes), and an -R won't work? Or different rules for different file-types?
    A blank disc has just over 4450MB (around 4.38GB) available.
