I have just changed to XP from WIN 2000 and my HDD(WD 160GB) won't operate. I can see it in disc management with a red cross on it, but there seems nothing I can do to get it recognized. I have lots of stuff on there so I don't want to format. What is the problem here and how do I fix it? BTW the drive worked OK till the change.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
You likely have to install a SATA driver for the SATA controller. Can you check in your Device Manager and see if you have a yellow checkmark beside a 'mass storage device' or similar? If so, that's what needs the driver. If you didn't install the driver when you installed W2000, that may be the problem.
Thanks redwudz I worked on this problem till 3am in the morning and still got nowhere. I've found that the drive is recognised by the computer when booting up, but not by windows. In the device manager there are no signs of it. If I go to disc management it says it is "missing" I would try the driver suggestion but need more technical advice on how to go about it. Can someone help me with that, thanks.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Thanks redwudz you have solved my problem, and possibly restored my sanity. I was not looking for the "mass controller" item, but after I read your post I noticed it and updated the driver, and "bingo" the HDD appeared. Thanks again for your help.
Don't forget a couple of things:
1) To update your "Computer Details" in your VH profile.
2) Buy your wife some flowers and beg for forgiveness...
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I like 'possibly restoring sanity'.
Win 2K isn't so 'user friendly' as XP and needs a little help at times. Don't ask me about W98, I still have configuration nightmares.
Anyway, good deal that you solved the problem.
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
External Sata Drive Not Being Recognized
By imdaman in forum ComputerReplies: 3Last Post: 17th Apr 2010, 00:30 -
What SATA Drive?
By lc in forum DVD & Blu-ray WritersReplies: 10Last Post: 21st Jan 2008, 17:22 -
Best SATA drive?
By shyamt in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Aug 2007, 14:08 -
IDE + Sata Drive ?
By StoneColdWhat in forum ComputerReplies: 4Last Post: 17th May 2007, 16:50
