If the codec was installed by an install.exe, I would just run the uninstall program.
If the codec does not have an uninstall program, I could go to Gspot in advanced mode and unregister the codec from here.
But the codec is just unregistered, it is still on the hard drive. Yes I could delete the *.ax file on the hard drive, but perhaps I will miss some components.
So is there a clean way to fully uninstall a codec if there's no uninstall program?
codec sniper < personally never worked for me..
I go in manually
Open
C:\windows\system32\
and Open Regedit
LM\Software\Microsoft\WindowsNT\CurrentVersion\Dri vers32
Its usefull to have AVIcodec a program that identifies the codecs
Remove the DLL and the Regitry Reference to that DLL and its Gone for ever. -
From the original post they are talking about directshow filters, not codecs though.
Yes, unregistering and deleting the ax file will do it.
For VfW codec's, there are a few more registry filters that you might want to clean out (such as HKLM\SYSTEM\CurrentControlSet\Control\MediaResourc es\icm), but they aren't as important.
If a dshow filter did have an uninstaller, all it would do is unregister and delete the file. -
Why would a codec just stop deinterlacing properly?
By Maralez in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 18th Aug 2009, 00:26 -
uninstall every trace of any video codec
By greendesert in forum Software PlayingReplies: 8Last Post: 20th May 2008, 11:27 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 16:09 -
Videos not playing properly - Codec Problem - HELP PLEASE
By Man-bear-pig in forum Software PlayingReplies: 1Last Post: 10th Feb 2008, 00:59 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 10:55
