I tried to burn 2 AVIs into one DVD, but Avi2DVD won't let me. it says somthing like "job 2 cannot have the same output as job 1." job 1 is my 1st avi and job 2 is my 2nd avi. if AVi2DVD doesn't work, what can I burn 2 AVIs into one DVD. I want to watch it on DVD Player on TV.
Results 1 to 13 of 13
Do you want the two files as seperate titles on the same DVD, or do you want it to join the files into one continuous title ?
https://forum.videohelp.com/viewtopic.php?p=1531467#1531467 might assist of it is the latter.
For the former I would assume that you need to put the two AVIs into the same job. I'm not familiar with the software though so I can't tell you how to do it.If in doubt, Google it. -
seperate titles r ok. if i play the dvd, it continues to the 2nd part after it finishes with the 1st part, right?
from the link you gave me, it says to rename the 2 AVIs into xxcd1.avi and xxcd2.avi. I did rename my 2 AVIs into cd1.avi and cd2.avi. but when i add cd1.avi as job 1, it doesn't seek out cd2.avi as job 2. help! please!
From what I was able to read, it does not seek out cd2.avi as job 2 - it joins cd1.avi and cd2.avi and processes them both as Job 1.
[EDIT]
from http://www.divx-digest.com/articles/article_avi2dvd_page1.html :
File preparation:
Put avi, ogm, mkv, or wmv file(s) and subtitles in a simple path such as D:\Movie. Let’s say your first half of a movie is your CD1 and your second half is your CD2
If you have a movie with 2 parts, for example, rename them like this: Test CD1.avi and Test CD2.avi
For subtitles, do the same like this: Test English CD1.srt, Test English CD2.srt, Test French CD1.srt, Test French CD2.srt
The CD1, CD2, CD3 etc…are important for Avi2DVD to accept and arrange your files correctly. Now let’s load Avi2DVD to start the guide
Step 1: Input
With Avi mode selected, press “Load avi/ogm/mkv/wmv. On the Open dialog, you just browse to D:\Movie, open the Test CD1.avi, and Avi2DVD will automatically load all the files for you.If in doubt, Google it. -
seanpatrick924,
Firstly, welcome to VideoHelp!
On this forum, it is generally accepted that if you need a question answered you create a new topic for it, as opposed to "threadjacking" by asking it in another person's thread. If you'd like to create a new topic for your question, I'd greatly appreciate it.
If there's anything else I can help you with, please don't hesitate to drop me a line.
Many thanks,
Cobra -
I tried the guide you gave me, but when I was about to make that mpeg file, it says the output file size will be 9.4 gb!!!!!!!!!!! that's too big, and I don't know how to shrink it to less than 4.7gb so that it fits on one dvd. help please!!!!!!!!!Originally Posted by jimmalenko
I just convert my 2 AVIs into VOBs with DivxtoDVD, and the VOBs plays fine in my pc when I checked it. Then I burned the VOBs with DVD Shrink, and it failed!!!!!!!!!!!!!! It says it didn't burn successfully, and I don't remember what the error pop up said. But what is the problem? THe VOBs were okay, is it DVD Shrinks problem? Please help before I burn another DVD!!!! I don't want to waste another DVD. By the way, the error DVD I burned out played fine, just that it did not burn the entire thing, like it stopped I meant frozed at 3/5 of the length when I played it with my stand alone DVD player.
oh I tried to burn it with Nero Burning Rom, and it works. I think it's the burning program's problem?
AVI to DVD with soft subtitle and menu with AVI2DVD
By kschang in forum User guidesReplies: 95Last Post: 7th Feb 2011, 17:55 -
Trying to convert AVI to DVD using AVI2DVD
By justmehere in forum Video ConversionReplies: 2Last Post: 22nd Jan 2009, 10:28 -
Why are my AVI2DVD dvd ISO files TOO BIG to burn onto DVD!?
By Xenogear900 in forum Authoring (DVD)Replies: 5Last Post: 1st Sep 2008, 22:20 -
Problem converting avi to dvd format with Avi2dvd
By bgart13 in forum Video ConversionReplies: 0Last Post: 13th Apr 2008, 17:27 -
Multiple AVIs to one DVD
By 64RedMustang in forum Authoring (DVD)Replies: 7Last Post: 13th Sep 2007, 19:42
