i have audio which is 855.60mb.i want to use the rest of space for vids to burn on DVD+R.A DVD+R is 4480mb. So 4480-855.60=vid space?
That's correct. The more used number is 4.37GB for a DVD-5, and you need to allow some room for authoring, maybe 100-200MB. Don't cut it too close, as different programs will give you different numbers. Encoders are rarely correct for hitting exact bitrate estimates.
What's your audio format? AC3 is more compact and compliant than MPEG-1, layer 2. But if you already have 5.1, that's probably the best.
Calculating Proper Scale According to Aspect
By WARnux in forum Software PlayingReplies: 6Last Post: 24th Jul 2010, 07:41 -
Calculating letterbox in AVS
By AlanHK in forum Video ConversionReplies: 5Last Post: 26th Oct 2009, 04:50 -
Am I calculating resolution correctly?
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 24th Sep 2009, 07:37 -
Calculating Video Length
By scan in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2008, 12:33 -
Calculating a bit rate
By haile in forum Newbie / General discussionsReplies: 5Last Post: 30th Apr 2008, 08:03
