Is there a way to reset or get back the MPEG 2 option in the latest version of TMPG?? I was playing with it and my system clock - I set it ahead to see what would happen (of course it said my 30 days had expired) and then I set it back to the right date and it still says my 30 days have expired. I see no option to purchase it anywhere.... Please email if possible - james33@midsouth.rr.com
Thanks for any help!!
James
Hi James,
I have definitely seen a post in the forum in the recent past that provides a solution to the '30 day' limit problem that you encountered. It has to do with removing a certain entry for TMPGEnc in the Windows registry, after which you can use TMPGEnc's MPEG2 encoding facility again for another 30 days!
Do a search and see whether you can find it. If not, I will try to locate my hard-copy of this solution (I printed it out for reference) and will forward you its conten.
Regards
Tan -
Hi James,
This is was suggested by member low_iq_88 in a topic entitle "TMPGEnc 30 day MPEG-2 limit" that was circulating around 12-19-2001.
"The 30 day limit can be reset by deleting the following registry key:
HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}
Or, make a file "TMPGEnc_MPEG2_Reset.reg" with the following content:
REGEDIT4
; Enables TMPGEnc's MPEG-2 encoder for 30 more days.
[-HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}]".
You may want to locate the various responses to the original discussion for more info.
Cheers
Tan
Regards
Tan
bd rebuilder expired
By davebarnes2009 in forum Blu-ray RippingReplies: 4Last Post: 4th Aug 2009, 15:59 -
DVD2oneX2 - Expiration expired (Is there....)
By JonnyPhoenyx in forum MacReplies: 5Last Post: 8th Mar 2009, 14:17 -
TMPGEnc has expired what do I do?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 14:55 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 10:25 -
My sony vegas trial has expired, how to register?
By muff1n in forum Newbie / General discussionsReplies: 11Last Post: 6th May 2007, 10:43
