I have a divx video I want to convert to DVD mpeg2. The file format:
divx 6, 512x384, NTSC 29,97 fps, 1779,20 kb/s, mp3 audio.
How do I scale this video to a DVD compliant format?
I have QuickTime Pro 7, Toast 7, Mpeg streamclip and Apple Compressor 3.0.2 on my Powerbook G4 (1,25 MHZ).
I have tried to use streamclip DV export and the "X/Y" aspect ratio to scale the video and add black bars on the side, but I do not understand how to do this properly.
Is it an option to use Toast 7 for this conversion?
Any help would be greatly appreciated!
Regards
Bjorn
Yes, Toast will take care of the proper scaling.Originally Posted by Bjorn
No need for black bars as the source video is 4:3.Originally Posted by Bjorn -
Since the frame size is 4:3 you can pretty much assume it's 4:3 display aspect ratio. Just resize to 720x576 and burn as 4:3 PAL DVD.
Thank you for your advice! Toast did a very good job with the conversion, it is a great application.
I also have another question regarding conversion/scaling. I have a SVCD file that I want to put on a DVD. I have changed the audio from 44,1 to 48 KHZ, but the video is the problem:
mpeg2, 480x480, 4:3, NTSC-FILM 23,976 fps, 2,52 mbps
I have made a version by using Streamclip - export as QuickTime, Apple DV-NTSC, framerate 23,976 and 480x480. I encoded the DV to mpeg2 in Apple Compressor with the 24P preset (NTSC-FILM with 3:2 pulldown). I let Apple Compressor do the scaling from 480x480 to 720x480. The DVD looks OK, but I am not sure if this is the best way to do this conversion.
Any suggestions? -
One thing you can try is using an MPEG file modifier to make the header(s) say the file is 720x480. Then author that to DVD without reencoding. It will not be to spec (so you wouldn't want to do this if you are producing commercial DVDs) but most players will play it properly.
I don't know what Mac programs can do this. You can read through messages about DVD Patcher (MS Windows) to get an idea how this works.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
512x384 to DVD? Full D1 or Half D1?
By rayden54 in forum Video ConversionReplies: 19Last Post: 9th Sep 2009, 00:44 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
