    Mar 2004
    Hi,
    I have Ice Age DVD which contains both (widescreen/letterbox) versions, I use DVD Shrink to shrink my dvd's. DVD Shrink identified "Title1" and "Title2" is there any tool which tell me which one is "16:9" and which one is "letterbox"
    Thanx
    NOTE: I did a search on this forum but as you know it's an ocean... I could not get the answer....
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    If you click on each title, then use the preview (bottom left), you can see which one cuts off the sides (fullscreen).
    Apr 2004
    Fairfax County, VA, USA
    you mean 4:3/"pan and scan" and 16:9/widescreen/letterbox.
    widescreen and letterbox are synonyms.
    Mar 2004
    Yes I means 4:3 and 16:9
