iam using winavi to convert from avi to dvd. i use dvd shrink to burn all was fine. for some reason in the last two weeks i have problems. i use winavi and it converts fine i use dvd skrink and all burns fine. i put the dvdrw into my stand alone dvd player and it plays the movie fine until about 30 minutes. after this the picture freezes but the voloume and speech are fine. i try and go to the next chapter and still the same thing. when i burn a bin and cue file everthing works fine. iam i missing a file or something. i cannot figured this out. i have tried dvd santa and divxtodvd with the same problem what iam doing wrong.
thanks
Could be a number of things:
- First, you're not using DVDShrink to burn. It uses DVDDecrypter, Nero, or CopyToDVD to burn. I think you can even configure it to use IMGBurn.
- Is the same freezing behaviour present when played on a PC ?
- What happens if you burn to a DVDR instead of a DVDRW ?
- Is it possible the source video has errors in it ?If in doubt, Google it. -
when i play it back on the pc there is no freezing at all. i wonder if iam missing a file or something.
thats what i was thinking but i have 8 of them and all dics do it any other ideas
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
