  1. I need help with TMPGEnc Author, same problem in 1.5 and 1.6. When I go to compile a VRO file written on a Panasonic DVD burner using RAM, I get a the file output just fine, but TMP just seems to pick a random spot and it stops. In other words, no matter what I direct it to do, it will not finish processing the entire VRO file. It indicates it has but is has not. It is written in fixed bitrate, SP format, and I try to read from both the DVD and from files transferred to the HD. When I view the file, it is all there and TMP sees it as all there when I edit. I have done this stuff before and it always worked. I have reinstalled the software and tried a different RAM disc to no avail.
    Is there any other software that works for translating VRO files or does anyone have a solution?
    Still a few bugs in the system...
    Mar 2004
    Southern California
    I had a similar problem a couple of years ago. My recorder was writing chapters and TDA would only author up to the first chapter point. I had to disable the autochapter function in the recorder to get TDA to see the entire movie. Hope this helps.
  3. Well, it goes way beyond any chapter and I know the discs have no chapters. Maybe full formatting will do some good.
    Clearly Author thinks something is there to stop it.
