    Feb 2005
    Zagreb, Croatia
    Hello,
    I have Sony DAV-SR2 system and it was multi-region.
    Modification was done by entering in "Service" menu and with
    some kind of remote control. Power button blinked 5 times
    and it was done. That was 2 years ago.
    I accidentaly entered "Service In" menu and probably
    re-set the entire system and now it is only R2 player as original.
    What can I do? It seems that I can't get to that remote control
    originally used for hacking.
    I heard that it can be done with laptop (and IrDA port) thru DOS.
    My lapton doesn't have built-in IrDA port. Can I use USB one?
    Will it work in DOS?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Most Sony's are not region free capable or require special remotes to perform the hack.
    Try looking your player up in the DVD Players section or try Google.
    Google is your Friend
