    quebec
    I have dvdlab-pro and i am in the process of making a DVD for our amator movie with multiple audio track, subtitle... all of it. But i have a small problem.
    DVD-LAB keep telling me the audio don't match between them and this can cause problem. I have 4 track of audio in one movie 1 is a (48 khz, 384 kps, stereo) the 3 other are (48 khz, 16 bits, PCM). I think the problem is there but how can i convert the 3 track (coming from wav file) into the same setting of the first one.
    Thnaks
    Shadu
    Apr 2004
    Miskatonic U
    ffmpeggui can convert your PCM tracks to 2 channel (stereo) AC3.
    I am surprised DVD Lab Pro is having an issue with different formats on the one movie. It is not compliant, and will get you warnings, if you have different titles in the same VTS that have different formats on the same track (eg. title 1 has AC3 on track 1, title 2 has PCM on track 1), but different formsta on a single title is permissible (eg. title 1, track 1 5.1 AC3, track 2 2.0 AC3, track 3 DTS etc)
    The other possible issue is that PCM eats a lot of space, so having 3 PCM tracks may be pushing you over the size limit (depends on the length of the movie, of course)
    Read my blog here.
    quebec
    Thanks... I will try that.
    By looking at the help file i did think about making multiple VTS but is it possible to simply drag a menu/video from one VTS to a other or i must remake all the menu?
    Shadu
