For some reason, there are certain video effects in APP 1.5 which I cannot render.
For instance, I cannot render any of the ones in the Stylize folder of video effects, while I can render ones from the transform folder (after I rebooted my pc and the s/w).
It could be a codec problem, i thought, but i'm only doing some work on a jpg. I do have some mpg in the sequence, but they were fine. Any case I uninstalled my K-Lite Mega Codecs anyways to see if it solved the issue.
No luck since.
Help~!
Hi Sandoria,
Try searching and / or posting in the forums at www.wrigleyvideo.com/videotutorial - the site is heavily into Premiere...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Rendering Effects in Premiere CS3
By Cherbette in forum EditingReplies: 3Last Post: 20th Sep 2011, 23:47 -
FAST RENDERING of Final Cut Studio Pro and After Effects files.
By Kevin Whelan in forum MacReplies: 3Last Post: 24th Aug 2011, 11:40 -
premiere pro rendering question
By thecrock in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2009, 16:30 -
Rendering problems Premiere Pro CS3
By tangosalon in forum EditingReplies: 2Last Post: 15th Jan 2009, 14:29 -
Premiere Pro Video effects - comparing one to another
By longlostname in forum EditingReplies: 3Last Post: 10th Oct 2008, 12:51
