I have owned a DVD+/-R DL burner for two years and this is my first time authoring a DVD-9 disc. I currently have my project in Ulead DVD Workshop. I exported this into a Video_TS folder. Now, AFAIK, there is no layer break in my project. What program do I use to force/create a layer break? Also, the DVD I am doing is a live performance thats divided into two acts. Since it doesn't break the coherency of the performance, is it possible to make the layer break appear in between the two acts (where I have a chapter mark)? One more question: How compatible are DVD+R DLs? I intend to use a Verbatim DVD+R DL, which is supposed to be very high quality.
For compatability, if your burner supports it, bitset the +R DL so it appears to the player to be a commercial DVD-ROM. It won't resolve all compatability issues, but it may help some players read it where they might otherwise refuse.
As for layer breaks, do a search as there are a couple of very comprehensive posts arguing the pros and cons of various methods. Be aware that the layer break position is constarined in part by the way you have authored the disc, and in part by the physical constraints in burning two layers.Read my blog here.
I've found the Verbatim DLs to be very good for dual-layer authoring.
"The avalanche has already started; it is too late for the pebbles to vote." -
This is probably the longest post on the subject. Start at the end and work backwards
https://forum.videohelp.com/viewtopic.php?t=225001Read my blog here.
DVD Players That Handle The Layer ...Break Well.
By Goblin~Magnet in forum DVD & Blu-ray PlayersReplies: 8Last Post: 1st Jul 2010, 08:43 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
Best place for a layer break with DL DVD+R?
By hiimbored in forum DVD RippingReplies: 1Last Post: 26th Nov 2008, 20:18 -
DVD+R DL layer break problems
By The-One in forum DVD RippingReplies: 1Last Post: 21st Oct 2007, 15:34 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
