Hi all. Was wonding if it's possible to merge two miniDVD's using a video editor, say Ulead VideoStudio 10 or Adobe Premiere Elements 2.0? Or can you only merge miniDVD's using dvdremake?
Define Merge. DVD Remake Pro is a great tool for merging if you want to keep the original menus. I would only use an editor to do this if you need to edit the contents together. If it is just a metter of merging content, there are better tools.
If you don't need the original menus, you can use DVD Shrink in reauthor mode. You won't get any menus from this method however.
TDA could also be used to bring the contents together, as well building a menu.Read my blog here.
By merge I mean keeping the original menus and have a menu that shows 'Disk 1' and 'Disk 2' when you put a dvd in a player, for example. I know DVD Remake can do this but was wondering if a video editor can do this as well. Also, what's the major difference between DVD Remake and Dvd Remake Pro? I know this question doesn't belong here, but thought I'd ask...
Best answered by going to the DVD Remake site and looking at the products.
Editors work at the video level, not the disc level. Even editors that are all-in-one and can produce DVD structures as output cannot read those structures inand modify them.Read my blog here.
Automatic Merging of video files
By dhaneshjs in forum EditingReplies: 2Last Post: 25th Apr 2012, 12:14 -
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 02:06 -
Pixelated video after merging sound with mkvmerge
By turbines in forum DVD RippingReplies: 0Last Post: 19th Jun 2010, 13:58 -
Merging video from JVC camera
By brucexx in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 17th Apr 2010, 13:17 -
Video mepeg merging/combining
By rbrass1981 in forum EditingReplies: 2Last Post: 11th Dec 2009, 09:03
