I have 450 mp3's (1.8 GB total) that I want to put on a DVD and be able to play them through my DVD player.
My DVD player doesn't support DVD mp3, only CD mp3.
Is there a way to convert the mp3's onto a DVD with audio only?
I'd rather not have to buy a new DVD player.
Thanks.
This will also do what you want, Good Luck
http://www.audio-dvd-creator.com/index.htm
http://audio-dvd-creator.com/guide.htm -
So will DVD Lab Pro and pretty much any authoring application. All you need to do is convert the mp3 to AC3 (ffmpeggui), and author these against either a still or a blank video clip.
Read my blog here.
Thanks for the replies.
I already tried DVDSanta (trial version, no limitations except watermark on video), and it would only let me load about 30 songs. Perhaps the trial version does have limitations.
I think Audio DVD Creator looks like the easiest tool to use. -
There's a couple of guides in the guides section that may assist -
https://www.videohelp.com/guides.php?guideid=580&howtoselect=3;6#580
https://www.videohelp.com/guides.php?guideid=476&howtoselect=3;6#476
https://www.videohelp.com/guides.php?guideid=903&howtoselect=3;24#903
https://www.videohelp.com/guides.php?guideid=757&howtoselect=3;24#757
Or if you wanted to get groovy, you could add WinAmp visualisations:
https://www.videohelp.com/guides.php?guideid=460&howtoselect=1;55#460
Of course one issue you'll run into is the 99 title, 99 chapter limit. This means that you'll need to organise the tracks in such a way that they are grouped, be it by genre or by artist or by album or whatever, because you won't be able to create 450 tracks.If in doubt, Google it.
Creating a DVD using VOBS & MP3s
By ZenFrog76 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2009, 03:00 -
Can't play MP3s on my Sony DVP NS355 DVD player
By harrylentil in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Aug 2009, 14:04 -
mixing 2 mp3s together
By motleycool in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2009, 09:04 -
mp3s to a dvd
By AeR0 in forum AudioReplies: 8Last Post: 2nd Aug 2008, 16:48 -
What software should I use to extract DVD audio and convert it to mp3s?
By maccaneer in forum MacReplies: 2Last Post: 4th Sep 2007, 18:03
