i have used many programs but either it is unsaportred or thier is some unknown error
convertxtodvd works well. not sure if it allows mixed sources though. might have to all be encoded the same to start.
ConvertXtoDVD will take multiple different sources and create a single DVD.
If you are getting unsupported there is a good chance to you need to install the correct codecs. Use g-spot 2.52beta or avicodec to determine what codecs you are missing, and install just those codecs.Read my blog here.
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 15:18 -
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Convert WMV to AVI / DivX / Xvid
By p_uriel in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 21:40 -
Looking to convert avi ( xvid ) to decent quality flv videos
By mordor in forum Video ConversionReplies: 0Last Post: 26th Oct 2009, 02:56 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 02:22
