this might not be a video question but relates to PAR and RAR files:
I downloaded a set of PAR2 files and after opening the program the result was a file type called .cbr
don't know that this is or what to do with it.
thanks and appologies is this is not the correct place to ask, but this group is extremely knowledgable and polite!
cheers
rotuts
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Print this out and stick next to your monitor:
.cbr=.rar
.cbz=.zip
change the extention to the other, then it will unpack.
(left to right, never right to left)
stick with me, i got TONS more USENET goodness for ya!
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
There's a number of apps for OS X that'll let you 'treat' the archives (.cbr/.cbz, or even plain .rar and .zip, if whoever created them chose not to rename them to cbr/cbz) as digital comic books (one's referenced in ffooky's post, but there are others, including FFView and Jomic, so you can take your pick. Search on MacUpdate and VersionTracker for more (I think I even saw one from Japan, that wasn't listed on either).)
Or, as terryj suggested, you can always just treat the .cbr like a normal RAR archive and view the images inside as you normally would.
If cameras add ten pounds, why would people want to eat them? -
of course as usual right again.
changing to .rar worked. they were comics!
but the ref by ffooky is a link that seems to be broken!
thanks and cheers!MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card
PAR and/or DAR prolem, not sure which
By fatcharlie in forum Video ConversionReplies: 3Last Post: 26th Apr 2011, 15:48 -
lost with par, dar etc
By kkiller23 in forum DVD RippingReplies: 12Last Post: 16th Sep 2010, 23:05 -
is there a PAR converter?
By snadge in forum Video ConversionReplies: 2Last Post: 7th Feb 2010, 10:36 -
544x416 PAR?
By teknix1 in forum Video ConversionReplies: 6Last Post: 15th Feb 2008, 16:28 -
Photoshop PAR
By kippard in forum ComputerReplies: 2Last Post: 7th Oct 2007, 03:15
