Hi-
What is the process for extracting audio from a dvd, editing it and then re-encoding it back into the original dvd?
Thanks for your help,
Mark
It depends on the source audio format (LPCM, MP2, AC3, DTS), number of channels, and the type of editing.
The basic method is demux the audio from the disc, convert it to either one stereo or multiple mono wav files, depending on the number of source channels, make your edits, then re-encode.
The main rule that you must observe to avoid great disappointment is that the length of the audio must never change
There are plenty of guides available for each stage, and if you search the forums for "Back to the Future" you will find some long posts on a project to edit out some of the language and create a combined 1 - 2 - 3 version of the movie.
Tools to look for (and to check out the guides associated with) include IFOEdit, Rejig, PGCEdit, BeSweet, Hypercube Transcoder and HeadAC3heRead my blog here.
Sorry for the NEWB question. Edit DVD.
By MPTech in forum Newbie / General discussionsReplies: 2Last Post: 25th Oct 2010, 18:50 -
Burnt DL playback question on DVD players, Edit: fixed
By WBFAir in forum DVD & Blu-ray PlayersReplies: 6Last Post: 23rd Jul 2008, 10:02 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13 -
How to edit multi audio dvd s ? (dts, dolby digital keeping both)
By live4fun in forum EditingReplies: 10Last Post: 3rd Jul 2007, 04:08 -
PGC Edit Question
By jordanwalkert in forum EditingReplies: 0Last Post: 7th May 2007, 15:10
