Is there a free(high hopes) or a pay plug-in for PS that can make extracting an image easier. I recently saw a program plug-in that was $150 or so that made it simple to extract an image (no tracing then erasing if needed). Free
Results 1 to 15 of 15
What We Do In Life, Echoes In Eternity....
Circling the desired object with the magnetic lasso tool, and right clicking "new layer via cut" should be a lot cheaper than a plugin
There's many ways to create selections (magic wand, range, lasso)..
But i've never seen any quicker and accurate way to do this..
I'll be watching this post..
I have seen a plug-in ($150) that will extract what you want from an image very simply and cleanly. Basically the same as doing a Filter/extract process, but no need to actualy trace the object totally.Originally Posted by pijetro
In response to live4ever's comment:
Say taking an image and cutting out a person only, with no background ect....What We Do In Life, Echoes In Eternity.... -
Depending on the image, sometimes the MagLasso tool works great, sometimes terribly. Then otherwise, you have to resort to zooming in and manually tracing. Hair is particularly daunting.
There are a number (>10) of plugins that work on extracting/"cutting out" a foreground image from a background. Do a google search on "Photoshop" "plugin" and "matte", "mask", "key" etc. Guess what...None are Free (this is a complex feature that is in demand and people are willing to pay good money for if it works right and helps speed things up).
(I guess it also depends on what your level of acceptability is too) -
Yea I have the CS version, and I have used the extract function....it does work great, but tracing is so slow and time consuming depending on the type of pic/image. I did see that one for $150, but for my novice expertise, not worth my money yet.....
None of the plugins will give you an instant extract. The closest you would find to this would be something like Primatte, essentially a green screen for stills. But extracting objects from standard photographs takes time, like it or not. The better masking plugins assist with things like hair and smoke, but you still have to do the bulk of the grunt work yourself.
Read my blog here.
ok thanks.........
Well I did find that plugin that cost $189 again it was called Fluid Mask 2.0 http://www.photoshopsupport.com/photoshop-blog/06/06/fluid-mask-for-mac.htmlWhat We Do In Life, Echoes In Eternity.... -
Digital Film Tools Snap. But I'm afraid it is'nt free.
http://www.digitalfilmtools.com/snap/ -
I've always heard from people who have used the aftermarket plugins that the built-in extract tool is far better for use with this even if it is a little time-consuming. I use the smart-trace feature most of the time and just do a little section at a time so that if I make a mistake the undo data won't take too much work away. Beats the old alpha channel knockout method for extracting.
FB-DIMM are the real cause of global warming -
Is this the filter/extract trace with green line way? If not how do you do yours?Originally Posted by rallynavvieWhat We Do In Life, Echoes In Eternity....
Check out Bert Monroy.
He gave Photoshop tutorials on G4TechTv awhile back.
He demonstrated the EXTRACT method using Photoshop 7.
http://www.bertmonroy.com/tutorials/tutorials.htmWhatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
Hair's a killer! I hate hair!Originally Posted by Cornucopia
I usually most often use the path tool myself for extracting stuff (out of habit, 'cause a friend showed me how a long, long time ago and I got pretty good at it), so the "extract" feature is like magic. Not to be too off topic, but I'd have to be extracting ten images a day to make it worth my $$$ to invest in a more expensive tool, though I can see that if someone's working for an ad agency or print shop that does this stuff all the time, it's a cheap and wonderful tool.
For me, because my goal of "cutting" an image means it's gonna get placed in some other image, the extraction part is only half the battle -- matching the edges and colors and lighting and tonal values so the composite final image "looks good" is where the time and blood is shed.
That always ends up being more about "art" than science, in that you can often figure out ways to disguise "flaws" in an image (like weird edges and artifacts that would take forever to clean up) by creative covering, texturing, a few paint dots here and there ...
Yeah, I use the extract feature where you trave with the green highlight pen and fill the parts to extract. Zoom in on part of the image you want to extract from within the filter dialog (where you highlight the outline) and then check the "smart highlight" or whatever that feature is called. Then size your brush to be maybe 50% larger than the useable outline you're going to use to highlight, meaning if the outline is blurry you'll want a larger brush, but if it's hi-res and clear you can use a smaller brush. Once I extract I then use the eraser, clone stamp, or smudge tool to clean it up. I've done a lot of pretty good extractions this way, but it is time-consuming.
New Adobe Photoshop image deblurring algorithm
By poisondeathray in forum Latest Video NewsReplies: 3Last Post: 14th Oct 2011, 00:12 -
Mplayer image extract: my TGA is blue!
By RogerTango in forum Video ConversionReplies: 0Last Post: 30th Apr 2011, 14:11 -
extract music from bin image?
By pensioner in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2011, 00:01 -
Photoshop filter/plugin - glossy light effect?
By Ai Haibara in forum ComputerReplies: 2Last Post: 30th Jan 2008, 20:39 -
Using Avisynth Transition PlugIn For AVI Still Image Slideshow
By wiseant in forum Video ConversionReplies: 4Last Post: 24th Oct 2007, 13:45
