  1. ok, this is probably easy:
    i have ex label xpress and i want to print out cd labels (the kind you put on the actual cd). what is the "offical name" of the sticky paper i need to print it on? i just dont want to walk aropund staples searching for something i dont even know the name of. thanks!
  2. They're called Neato CD/DVD labels but read this first:
    https://forum.videohelp.com/viewtopic.php?t=303141&highlight=
  3. ok, so basically if i want one i need an ink jet printer. but how does that work? do i just use an inkjet printer to print the neato labels and it'll be fine? or do you somehow print on the actual dvd? help!
    If you do a search, you'll find MANY reasons not to use sticky labels on your CD/DVD. The printable CDs require a printer that can print CDs (and CDs that can be printed on) and the lightscribe DVDs require lightscribe media.
    When I first started with CD/DVD burning, I had to put labels on everything. It was fun creating them. Now, I just use a marker to label them.
    44E
  5. Originally Posted by cantckaja
    You need to use "inkjet printable media"(that have a white surface) and a printer such as an Epson R220.I use my Epson R220 for special DVD's(eg. holidays,birthdays,etc) and a Sharpie for everything else.
