My drive can no longer read DVD-Rs. IT can still read the normal dvds which you buy from the shop. The DVD-Rs used to work but now it doesn't. Tested it on other comps and it still works fine. Anyone got any idea how i can solve this problem? Only got the computer i'm using for a little over a year.
Results 1 to 12 of 12
i'm very new to this kind of things.. sorry but how do you clean the laser head?Originally Posted by ROF
Easiest method: Buy one of these. http://www.sjgreatdeals.com/sakdvd511.html
Do these things actually work? From what I've seen, there is no way to get to the laser apart from disassembling the drive as it sits below tray-level.
Yes. There are little brushes on the disc which wipe the laser. While not my preferred method of cleaning it is easier than cracking open the device case.
i tried using the cleaning disc.... but it didn't work. still can't read DVD-Rs. HOw ?
Is the drive not reading -R a burner or just a player? Whcih burner if a burner, and has firmware been upgraded? Specifically which -R media doesn't read? My NEC 3520A would burn or read Ritek G05 -R meida with 3.05 firmware but won't after upgrade to 3.07 firmware, but it still reads and burns Verbatim -R and TDK -R media. First thing I'd try is different media.
It wouldn't read DVD-Rs. nope the firmware hasn't been upgraded but i upgraded it after it wouldn't work but to no avail. It doesnn't read all forms of DVD-Rs of different brands even TDK. i'm using Lite-On DVDRW SOHW-1633S.Originally Posted by bevills1
Will it read DVD +R disks? Cleaning is likely not the issue if it reads +R but not -R because it'd likely have problems reading all media if cleaning were the issue. However, cleaning may well be the issue if +R media isn't read either. Perhaps check the LiteOn forum at http://club.cdfreaks.com/forumdisplay.php?f=44 where another user posts same problem, and the site has firmware links, FAQs and other useful info.
it can't read either DVD-R or DVD+R. i checked the forum but the person only seem to have problems reading DVD-Rs. How ? i tried cleaning but doesn't work. WHen i put in DVD-R or +Rs, there will be this whirlling/clicking sound. But it reads normal DVD just fine.Originally Posted by bevills1
Maybe time to replace the dirve if cleaning doesn't work since it doesn't read either media. NewEgg has very good drives under $40 shipping included, but I recommend avoiding NEC drives since they are rated below average for reading in review of NEC 3540A as well as other users have similar problems with NEC especially for -R media. After reading CDFreaks reviews, my first choice would be the Pioneer 111D and probably LG second due to its above average reading rating in reviews with Benq a close third.
Problem in reading a YUV file ... values are 205 !!
By krao in forum Newbie / General discussionsReplies: 17Last Post: 31st Jan 2011, 04:35 -
Damage Disc Reading Problem
By Teac23 in forum DVD RippingReplies: 18Last Post: 20th Mar 2010, 19:03 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 01:25 -
Problem reading media with LG RH4820v
By d1n1s in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Jul 2008, 15:43 -
problem reading some discs
By nick6878 in forum DVD RippingReplies: 5Last Post: 3rd Jan 2008, 11:25
