I once read a thread on here that pointed to a good guide on the right codecs to install and what options to set them up, but I cant seem to find it. Can someone point em to the aricle in question?
I'm not familar with that guide, however, the rule of thumb is to just install the codecs that you need. Whenever you come across a file that doesn't play, locate the codec needed and install it. For most files, all you will need is a mpeg2 codec and the latest divx codec.
Google is your Friend
CODECs
By channelk in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2011, 22:34 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 15:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52
