Hi,
i know this is a really old thing these days but i really need to make a copy of my old VHS tape onto another VHS tape, and just need to know how to connect two VCRS together.
Can someone please give me instructions on how i can do this, and what leads etc i would need.
Standard VHS VCR should have at least one video out (yellow RCA) and if stereo, two audio out (red and white RCAs). Connect these to the corresponding video in (yellow) and audio in (red and white for stereo). Set the recording VCR to the AV channel. Hit record, hit play on the other, and wait until it is finished.
Read my blog here.
If you have a DVD Recorder, then you should try connecting it between the two VCRs and using it in passthru mode by passing the playback VCR output through it to the record VCR input. This should improve the timing stability of the playback signal, resulting in a better looking copy.
Remember to set the source of the recording on the recording VCR. It needs to be set to Line-in or Line-1 or 2. Otherwise, it will record from the tuner.
Darryl
Servicing Panasonic S-VHS VCRs
By Gibson's Squares in forum Capturing and VCRReplies: 10Last Post: 1st Dec 2013, 12:22 -
Test of various VCRs Image Quality from VHS Tape (Big Pics)
By BrainStorm69 in forum RestorationReplies: 47Last Post: 2nd Aug 2013, 15:58 -
VHS tape recorded in Japan at different frequency than North American VCRs?
By sincostan45 in forum Capturing and VCRReplies: 9Last Post: 16th Mar 2010, 13:44 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
Test of SUPER-VHS playback quality for various VCRs
By theaveng in forum RestorationReplies: 5Last Post: 20th Aug 2008, 08:09
