I'm going to buy a new PC that has to do recent games and office stuff OK, which will just be displayed on the normal monitor and computer speakers. Decent, but not too bleeding edge hopefully.However I also want to use it to play retail DVDs and CDs, which will be displayed on the native 1024x768 projector in the living room next door (long VGA cable already in place) and use the 5.1 speakers via the living room receiver - SPDIF optical input.
Can you guys recommend components that will give me good results and minimum headaches? I guess I'll need a video card and DVD player software that support dual monitors "dual view". Would I need two sound cards, or maybe a sound card for the living room SPDIF passthrough, and use the motherboard sound for the PC speakers? Also, a remote control for the DVD player would be nice, maybe something like Streamzap?
http://www.the-gadgeteer.com/review/streamzap_pc_remote_review
I guess if I'm using the PC at the same time someone's watching a DVD in the living room, both users will not be able give input to the PC at the same time successfully, but that's OK.![]()
Any tips appreciated!
Note - the projector has a crappy upscaler, so I really want to feed it 1024x768. This has all worked very successfully using a momitsu DVD player outputting 1024x768 and optical SPDIF, but it died and I can't find a reasonable non-PC option.
The power of the pc will be decided by your gaming requirements. Normal everyday "office stuff" and dvd playback work quite well on generations old cpu's/hardware.
With that said, if you are wanting to multi-task, you will need a bit more cpu power, but still not as much as gaming itself. The biggest drawback with multi-tasking, is that there isn't an easy way of keep audio seperate. Normal pc sounds, dvd playback, games, all use the same audio path.
Your best option would be to track down a cheap standalone for your movie watching. Your new pc will work as a HTPC, but multi-tasking isn't an option.Google is your Friend
Trying to update ffmpeg components
By doodlebuggy in forum ffmpegX general discussionReplies: 2Last Post: 20th Jul 2011, 22:57 -
Getting DVD rips on to aaxa p2 pocket projector
By Duck in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2010, 13:32 -
Ffmpegx missing codec components?
By plugues in forum ffmpegX general discussionReplies: 5Last Post: 10th Oct 2009, 12:51 -
My Epson EMP TWD10 DVD Projector
By GazBelfast in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th Aug 2009, 13:44 -
Can not install mpeg components
By franks65 in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2008, 10:57
