    Sep 2004
    Australia / Newcastle
    I used dvd decrypter and successfully ripped a DVD to my hard drive. Its a long convoluted story but basically I accidently deleted the ripped DVD from my hard drive and the actual DVD is no longer viable..(dont ask..). anyway I found a program to recover deleted files from hard drive and recovered the data. When I use cloneDVD or DVD Shrink to make my back up I get an "error opening files". The actual VOB's seem ok, they play fine in PowerDVD.
    What is the easiest and best way to make a dvd with these VOB's?? I dont care about menus or anything ill be happy just to have a DVD play the VOB's.
    Please help me..
  2. Use TMPGenc DVDauthor and use the import DVD video option.
    Sep 2004
    SingSing Posted: Jun 28, 2006 23:49
    Error! Same as what i've tried before..
    I want to know the best/easiest way to re-author the VOB's onto a DVD..
  4. Mod Neophyte redwudz's Avatar
    USA
    That's one of the best and easiest ways. You might try using IFOEdit and reconstructing the the DVD format. If that fails, maybe extracting the MPEGs from the VOBS with a program like VOB2MPEG, then re-authoring them. Just because the file plays in a software player doesn't necessarily mean it's not a corrupted file. Software video players are much more forgiving than a standalone player or a program that needs a file with 0% errors.
    Sep 2004
    Hmmm, so there is no way to use the VOB's on their own??
  6. Maybe DVDShrink in reauthor mode?
    Apr 2004
    Miskatonic U
    Demux the VOBs with rejig and reauthor using the elemntary video and audio files. It sounds like the VOBs are suspect as it stands.
    Read my blog here.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The VOBs on their own are naked without corresponding IFO and BUP files that tell the DVD player exactly how to use information in the VOBs. Let me echo the sentiments of and recommend demuxing with VOBEdit (part of https://www.videohelp.com/guides.php?guideid=723#723 might assist) and then author with any authoring software that accepts elementary streams. Or, if you've only got one titleset, then http://members.dodo.net.au/~jimmalenko/test.htm may be of assistance.
    If in doubt, Google it.
