I ran into this problem while making a backup of Syriana. I used DVD FabDecryptor to put it on the HD. At this point the captions (while a foreign languange is being spoken) are there. Then on to DVD Shrink, the captions are gone. If I view the DVD Fab file with Shrink the captions do not show. I ran it through Shrink in both "Full-Disk" and "Re-Author" mode with the same result. I left all subpictures checked. I probably shut something off, but I have been unable to find it. Any ideas?
Thank You
Empty
Hi All,
I've tried a few other things without success, but maybe the info will help. I tried Nero Recode with the same result. Then I ripped with "Rip it for Me" w/DVD Decryptor 3.5.4.0 and the forced captions are lost before Shrink runs. However, this time they do not play using Power DVD either. Using DVD Fab Decryptor they do. At this point I don't know what else to try. Any other ideas out there?
Thank You
Empty -
I've kept playing around with this and found the captions are there, just not forced anymore. Does anyone know how I might fix this?
Thank You
Empty
Software DVD Player - Forced Letterbox
By GeorgeW in forum Software PlayingReplies: 3Last Post: 9th Nov 2011, 07:00 -
Forced subs on HD-DVD rip
By jlchavis0844 in forum SubtitleReplies: 6Last Post: 19th May 2010, 08:40 -
Forced DVD subtitles not showing
By joesphroth in forum Software PlayingReplies: 0Last Post: 10th Oct 2009, 21:22 -
How can I delete close captions from a DVD
By siopilos in forum SubtitleReplies: 3Last Post: 26th May 2008, 11:31 -
Determine if forced subs are on a DVD
By whatisk in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 19:42
