I have a few questions regarding DVD --> x264 conversion....
Firstly I'm looking for QUALITY, I don't mind the encoding time, since I'm only going to encode once. Secondly I plan to play it only on PC.
What is anamorphic encoding? Is it better than the normal resizing we do?
I'm not so fond of One Click apps, so which would be a good app for the encoding process. Also is there any difference quality wise (not feature wise) in CLI and VfW interfaces?
Any advanced user guides out there for encoding to x264?
Are Sharktooths profiles and compiles any better than the regular x264 profiles/compiles?
Are there any good custom matrices available?
Here's a site that explains a few key settings:
http://www.mplayerhq.hu/DOCS/HTML/en/menc-feat-x264.html
Here's one that tells you all about the settings, and links (at the bottom) to Gordian Knot guides:
http://www.doom9.org/index.html?/gknot-main6.htm
Anamorphic is 16:9 widescreen, non-anamorphic is 4:3 non-widescreen - these refer to the aspect ratio of the video. Get this wrong and the image will be distorted.
That's all I can help you with, I'm afraid. Hope you find it useful!
CLI is better than VFW as VFW is abandoned and doesnt support all features
Not entirly abondoned. It was updated with the recent API changes. There was a time when it wouldn't even compile because it was so out of date. Still best not to use it though.
Question about x264's Tuning settings
By CubDukat in forum Video ConversionReplies: 0Last Post: 4th Dec 2011, 23:17 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
DVD to X264(MKV) Question
By ron spencer in forum Video ConversionReplies: 5Last Post: 22nd Feb 2010, 19:10 -
X264 Question
By eric11111 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 11th Dec 2008, 19:07 -
X264 HDTV question
By JConnor in forum Newbie / General discussionsReplies: 2Last Post: 29th Sep 2007, 15:44
